ROAR can't start my damn car.
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Ok Guys and gals.. Someone who knows anything about fuel pumps or third gens can you help me out before i shoot my self or something....
Ok started off.... One day car died... When i go to start it no fuel pump kicking in.. Ok bad fuel pump... so i thought... replace fuel pump, And replaced the relay... I checked the fuse up by the battery as well.. Ok... all is well lets fire this sucker up.. WRONG... roll over nothing... Fuel pumps not even priming.. What the hell... so i get confused check power at the relay good. Ground at the relay... Good.. I try doing power to tan/white wire (supposed to go to fuel pump).. Assuming that would make it prime.. Nothing.
Ok all mighty car gods.. PLLLLLLEEEEAAAASE help me get the damn camaro started.
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: ROAR can't start my damn car.
https://www.thirdgen.org/forums/atta...g-now-aldl.gif hope this helps .shows how to check fuel pump,later jimmy
Car: 1991 transam
Axle/Gears: 4:10
this may help also, do a search on fuel pump prime test it pulls up a lot of different pages with different things you can try,later jimmy
