350 chev engine code help
i got the engine number off my block on the driver side it is 3970010
all i could find out with it is this
1969-79 350ci 185hp low-370hp high-2 or 4 bolt main-car, truck, Vette
Can you tell more from it?
also, as a side question, it has a giant harmonic balancer what does this mean?
Last edited by DirtyCanadian; 05-01-2008 at 12:09 AM. Reason: Automerged Doublepost
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Very common 70's block. Nothing special about it. Used in trucks to Vettes.
A large harmonic damper is typically a good thing. However, design is more important than size, condition comes right after that - most likely this one is a factory damper.
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: 350 chev engine code help
check behind the timing chain cover for a 10 20 casting on the block, it might be a high nickel block, witch dont amount to much other than it might be a little stronger block then normal, more ware resistant then anything....
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Groan....
It's an 010 block, the single most common engine casting on planet earth.
I have one. Heck, I bet 75% of this board has that block casting #.
Nothing special or unique. Just use it and go from there. Should have an 8" damper, just like all other 350's.
its larger than your average damper, biggest one i ever had on any of my small blocks
it has been balanced would that require a damper mod?
the motor has had 2500$ worth of work not including some parts so i dunno if it requires it, but im sure its like that 4 a reason.
Engine: LS1/LQ4
Unless you are installing it unmodified, it really doesn't matter what it once had.
Ok Got another one same cast number but I got more numbers, I have some numbers but no resources for them, Its numbers are 101198670 K0625CNR I know what its third number is 3970010, it tells me same as my other 350 but this one is different. The first two numbers i guess are supposed to tell you everything. Anyone have the resource for the first two numbers found above the head towards the intake?
