Edlebrock Intake Manifold
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Ok i read in the tech article on the website that manifolds for 86-prior, will fit a 95 block, all you have to do is enlarge 4 holes, is this correct? I dont want to buy a intake and not have it work.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Edlebrock Intake Manifold
You can buy the right beveled washers, but then you're right back where you started...
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Vortec heads require a Vortec-specific manifold, not an '86-earlier manifold.
'95 heads aren't Vortec.
What heads are you using?
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
193 heads are just swirlports. They're great heads, a lot of torque and great gas mileage, but they are definitely not meant to make any kind of serious horespower at all. If you're okay with that that's fine, but I just wanted to point that out before you went through a lot of extra trouble to make them work.
Car: 1992 Camaro RS
Engine: 3.1 V6
Im fine with the heads for now, maybe when i get in my porting class, i will P&P them. I just wanted to get a carbed intake for it but if i could just make 4 holes alil bit larger and not have to pay $40 more for a 1995 performer intake, then thats what i was gonna do. Will i need the wedges?
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
