oil dip stick question:) 1983 Z28
Car: 1983 Z28 Camaro
Engine: 350 block with original Cross Fire
Folks, I purchased a 1983 Z28 from my cousin and the first thing I know it needs is the complete oil dip stick setup. Right now I guess there is nothing there. It has a rebuilt engine that I haven't fired. 78 block, but it is still a passenger side setup. Where would I purchase the tube etc? Also, do you know if I can sneak it in there without lifting the engine back out? Thanks!!!
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: oil dip stick question:) 1983 Z28
I think Mr Gasket, or moroso sells them. It's a universal SBC thing. I bought it for about $18 off summit I think. Chrome to boot Or you can get a fancy shmancy Lokar one for $80. Your call (I can think of other ways to spend $60, like a 60oz of vodka maybe...)
You should be able to get it in there without lifting the engine. Driving it into place will be awkward. I think I grabbed an old 1/2" or 9/16" wrench, shoved the 12 point end over the bulge, and hammered on the wrench to drive it down. Drive it down until the bulge rests on the block and you're done.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Welcome aboard thirdgen.org.
If stock exhaust manifolds, the dipstick tube and manifold will want to be in the same place. Lokar flexible is the best option.
If headers, no problem. A parts store dip stick will be fine.
Thanks a bunch guys! I'll Need to go Lokar as it is stock exhaust. Where do I go to get the Lokar setup?
ambainb
04-25-2016 09:21 PM
Navy8125
08-21-2015 09:32 AM
