Connecting rod Diameter spec???
Old 04-27-2008 | 06:38 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
I'm looking for the inside diameter of a connecting rod off a 350 tpi motor. I'm looking for the measurement of the bare rod without the bearing installed. The big end of the rod. Can't find the measurement anywhere thanks!
Old 04-27-2008 | 06:59 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Connecting rod Diameter spec???
I just ooked in my 89 sevice manual and found nothing on that measurement.
might try calling a machine shop.
Old 04-27-2008 | 09:04 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
2.100+/-.001 inches
Old 04-27-2008 | 09:45 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Originally Posted by SpitotRs305
2.100+/-.001 inches
I hope not or else I need a new rod. LOL! Im getting 2.250 +/- .0005
Old 04-27-2008 | 10:42 PM
Car: 91 RS
Engine: 350 vortec
ok the connecting rod journal diameter should be 2.0978-2.0998
you are measuring the big end without a bearing installed getting 2.250-2.0978=.1522/2=0.0761-.0015=.0746
with a big end measureing 2.250 and a rod journal measuring on the low you need a bearing thickness of .0746 to provide enough oil clearance what do the old bearings measure?
what are you using to measure +/- .0005? hopefully not calipers...
Old 04-28-2008 | 08:42 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The GM spec for the large end of a large journal connecting rod is as follows:
2.2247" - 2.2252" diameter
Taper or out of round not to exceed 0.00015"
No bellmouthing permissible
1976, GM, Chevrolet Power book, 2nd edition, p. 1-16
RBob.
Old 04-28-2008 | 06:27 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
ok thanks for the replies. Im using a telescoping gauge with the auto centering feature. It can hold up to +/-.0001. The out of round spec kills me though. I guess I'll just get a new rod. Thanks for the help I couldn't find that measurement anywhere.
Old 04-28-2008 | 10:47 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
If you're dealing with a stock rod, try to find one that has the big-end balancing pad close to the same thickness as the original to keep the balance close. (that is, if you're getting a used one and you have a pile to choose from)
I've encountered one out of round rod before and it must have been dropped with the cap installed during a previous rebuild. Thank goodness for plastigage!
Old 04-28-2008 | 10:50 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Or better yet, just have the rod resized. It's $20/rod around here.
Old 04-28-2008 | 11:16 PM
Engine: 350 4BBL
If it's wider (bigger) across the parting line of the rod how are they supposed to grind that part of the rod smaller?
.\____/
I know they resurface the parting areas of the rod and cap, but the bore is vertical there. They would have to grind a bunch off of each to close it up.
I say pitch it!
You can buy a box full of rods at a junkyard for $20.
Or join the people that can't figure out why they have spun bearings...
Hotrodboba400
12-10-2019 08:07 PM
Jorlain
10-08-2015 02:57 AM
angel2794
09-08-2015 07:22 PM
Hotrodboba400
09-02-2015 08:28 PM
1Aauto
Sponsored Vendors
09-02-2015 02:35 PM
