New Engine plan... any comments?
Hey guys. I finally picked up an 88 350 long block to start my engine build. I wanted to run my idea past you guys to see what you think.
Here is the build.
350 block out of an 88 Firebird
This Voodoo Cam
These World Sportsman II Heads
I am going with 1.52 Comp Cams Magnum roller rockers, and the appropriate Lunati Springs to support the Cam lift.
I plan on re-using the crank and rods from the motor, getting flat-top or dished pistons to keep the compressions right around 9.1 or 9.3-1 and going with a TCI stall converter. The dyno at the machine shop said I should be running right around 300-320Hp and 400ft-lbs of torque at the flywheel.
I am keeping all the accessories from my 305 including my Q-jet carb, AC etc.
So what do you think? Decent or too much?
Here is the build.
This Voodoo Cam
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: New Engine plan... any comments?
first that particular cam is for an LS1
you might like some thing bigger than that anyway and more compression unless you plan on driving it every day
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
do it right stock rods and crank are weak, go for this poor boy special at least... http://www.strokermotor.com/RA383.htm
Car: 91 RS
Engine: 350 vortec
stock rods an crank that are inspec. will handle all the HP that engine is going to put out at this point besides that is $1000 of extras that you dont need to make a 350 fast... plus machining on top of that....
BINGO! Stock crank and rods should be good to 400 hp easy. Just upgrade the rod bolts. Thats truly one of the weakest links in the rotating assembly.
Car: 1991 Z28 1LE
Transmission: 4l60e
yeah well i wont argue with people over motor building just giving a sugestion, IMO using stock parts is just limiting yourself. specially when u can buy new better parts for a little bit more then having your stock stuff inspected and machined....id rather have a 350 thats making plenty of power that i dont have to worry about being a time bomb then having a motor running stock internals making power running on the ragged edge...you want a good reliable motor build it right with good parts and about 9:1 compression and have power and reliability.....
Car: 1991 Z28 1LE
Transmission: 4l60e
didnt see it but have heard of it, all well and good not saying that the sbc cant take some hellacious abuse, but lets not be ignorant about it, how long do you think that motor would last constantly on 500hp or maybe even 400....it could make it or it might blow, its a coin toss.....im saying for a lil bit more money he could build a qulity stout motor, but its a moot point cause for the 300 hp he wants stock stuff will be fine, but most people will want more after a while...
Is it possible to use a cam made for 1997 - 2002 in a 1988 block? I had a non-LS1 350 from a 96 Silverado that I wanted to put this cam in originally. However that block is now 1000 miles away in a storage facility. I didn't have enough room to bring it with me when I moved. I found an 88 Roller block and figured it would work. I thought Cams were pretty swappable overall?
Car: 1991 Z28 1LE
Transmission: 4l60e
as long as the cam is a gen 1 or even gen2 (lt1) roller cam u can use it....
LOL I've got a 67 Camaro sitting in a garage at my Parents place that needs a Frame-Off. When I get settled in a place where I have my own garage and can once again use my tools...I plan on going a little insane with it. Say...Twin Turbo LS7? hehehe You can click the link in my sig to see the car as it is now. Hasn't been driving since 2000...
Car: 1991 Z28 1LE
Transmission: 4l60e
nice 67, i had a 68 till about 3 months ago and i got rid of it to get some cash for my third gen....
Car: 1991 Z28 1LE
Transmission: 4l60e
try lun 60120lk, 60121lk, 60122lk,60123lk cams thats the roller voodoo cams.... http://store.summitracing.com/egnsea...view=sku#rstop
ls1 is a gen III motor, u can filter that on summit....
Last edited by igotta355z28; 04-16-2008 at 11:42 PM. Reason: Automerged Doublepost
Car: 1991 Z28 1LE
Transmission: 4l60e
http://store.summitracing.com/partde...0&autoview=sku here is a good cam for ya, works with stock convertor and everything..... take off the lk on thos part numbers i gave ya b4 sorry
Hmm...no, that's not bad at all. Mild enough for a daily driver and yet still fairly aggressive.
Car: 1991 Z28 1LE
Transmission: 4l60e
yeah that one i just gave u the link for is a voodoo cam, i got the number for it out of my lunati catalog and it lists it as a voodoo cam, summit just doesnt, and yeah that first link was just a bunch of cams.....the discription says it gives it a good milage and torque increase....
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
colton_carlson
03-08-2019 12:21 PM
kah992
08-19-2015 02:55 PM
