Starter grinding
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Starter grinding
I have a weird issue that started yesterday with my starter.. when the car is cool the starter engages no problem but when it gets warmed up after driving for a bit and i turn it off to go into a store or something i come out and start it again it sounds like the starter is grinding the teeth on the flexplate or soemthing and usually takes 2-3 times to engage it property ot start?.. what is the problem do u think?... bad starter? the starter might be loose? any ideas are appreciated i just got the motor running and have already found out that the valve seals are shot etc.. so time for new heads...
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 GTA
Engine: 350tpi,HSR, underdrive pulley,tbfb
Axle/Gears: 3.27 Posi
Re: Starter grinding
Definately sounds like a bad starter. check to make sure the flexplate is okay.
Gunner242
12-25-2015 04:49 PM
