Part impossible to find - Vacuum Y Connector
Old 04-04-2008, 03:08 AM
Jaime-TA-84's Avatar
Car: 1984 Firebird Trans Am
Axle/Gears: 3.73 Posi
The Y connector on the hose coming from the PCV valve is cracked and I cant find a replacement. It looks like this:
Code:
                                  /"""/ 1/4" O.D.
                  ______________/   /______
TO PCV VALVE <-- / 3/8" O.D.              / 3/8" O.D.
                /________________________/ --> To Base of Carb
I looked up the part number in the parts catalog and got 472852, but I searched with that number and nothing comes up.
The closest thing the parts stores around here (Kragen, Autozone, Pep Boys) have is one with a 3/16" smaller tube instead of 1/4".
Anyone know where I can find a "Y" hose connector that is 3/8" x 3/8" x 1/4"?
Old 04-04-2008, 04:37 AM
Icarus 402001's Avatar
Car: 92RS
Re: Part impossible to find - Vacuum Y Connector
A good hardare store will carry it.Plumbing department.
Old 04-04-2008, 11:03 AM
TGO - 10 Year Member
Received 1,861 Likes on 1,418 Posts
You're in danger of making "much ado about nothing"....
Just get what you can, and use it. Get one of those squeezy kind of hose clamps to hold the line on, if you need it; or put a couple of wraps of electrical tape on it; or use a "T" instead of a "Y" connector; or use a short piece of 3/16" line and a splice to the ¼" line.
Yes I know about CA inspection; I found out all about it when I moved out there with my L69 car. It'll pass by doing ANY of those things I suggested.
Old 04-04-2008, 01:00 PM
Youre right, I was hessitant to post about not finding the connector since it is pretty insignificant. I bought a package of various connectors and found one that has 3/8" on both ends and a much smaller diameter for the top branch (might be 3/16", not sure). I was able to saw off the end of another 1/4" connector and I was able to slide it over the top branch of the other one and glued it in place. I basically got what I was looking for, but now the top branch has a very small inner diameter. I'm not sure if it causes enough vacuum restriction to affect the operation of vacuum valve thing that hangs in the front of the carb.
Old 04-06-2008, 09:33 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by jaimegmr
... I basically got what I was looking for, but now the top branch has a very small inner diameter. I'm not sure if it causes enough vacuum restriction to affect the operation of vacuum valve thing that hangs in the front of the carb.
Here's a $3 solution. Just get a PCV valve like the one shown below that has the 1/4" hose connection on the other side :
Infested
05-22-2018 11:56 PM
TheJoeY88
12-31-2016 07:30 PM
Street Lethal
08-12-2015 11:33 AM
mizz0313
08-12-2015 06:45 AM
1nastygta
08-08-2015 07:38 PM
Quick Reply: Part impossible to find - Vacuum Y Connector
