starter is dead, can i start?
My starter is dead, its happend at mart parking lot. Can i start the engine by pushing the car with speed in and using clutch to turn the engine? I have 5 speed stick. Or it will not be allowed by clutch possition sensor control? If i dont push the clutch down, then the engine will not start. Thanks for help
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: starter is dead, can i start?
The clutch safety switch only keeps the starter from working, but the engine can still be started. Also, before you try push-starting it, try banging on the starter with a hammer or other heavy object. Most likely the starter solenoid is bad, and that may free it up, to get it home. I've used that trick a couple of times to get a car home with a failing starter.
Yes you can do that.
The switch on the clutch only prevents the starter from working; not the engine from running.
In fact, the clutch safety switch could possibly be the reason your starter doesn't work.
db057
08-11-2015 10:11 PM
