quick easy timing cover gasket question
when i first put my motor in there was a few drops of oil that would come out of the front of the oil pan in the middle. It got worse and I now believe it to be the timing cover gasket. My engine guy didnt use RTV on the paper timing cover gasket, is it completely necessary? whats the best way to keep all these new parts dry?! I'm using a one piece felpro oil pan gasket if it helps.
thanks a lot
thanks a lot
Re: quick easy timing cover gasket question
No, you shouldn't put RTV on the paper gasket; the paper gasket is ENTIRELY unnecessary. Use RTV only.
Got a bolt in this hole?
there is a bolt in there, im assuming it needs rtv as well so i will pull it out and check it. there does seem to be a BIT of water in the oil, at least on the back of the timing cover
thanks again
Yeah it'd be good to have a drop of RTV on the threads.... that hole, as is easy to see in that pic, goes right into the passage for the fuel pump rod. It's an EXTREMELY common new-motor mystery oil leak. BTDT... back before Al Gore invented the Internet, in fact I think he was probably still in college at the time, I found out about it the hard way, myself. Sure is easier to read stuff and see pictures nowadays, so things are easier to find out about!!
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
that hole does not go thru on all blocks. i have a late odel block and havent had anything in that hole since i put it in there. no the old motor would leak out that hole
But yeah, all blocks up from 55 till at least some time near about 90, have it drilled.
1992 Trans Am
05-10-2023 07:19 PM
NinjaNife
08-23-2015 11:49 AM
