Hooking up speedo
Car: 1991 Formula
Engine: 5.7
Hooking up speedo
Heres the situation. car is switched over to a carb setup. ECU and all the unnessary wiring is gone. my tach, fuel and voltage still work. Can i use the stock gauge cluster(speedo) without the ecu? speedo does n't work right now.
Do i need after market gauges? and if so which do i get to hook up to my 700r4?
