Hand Held Tachometer Where Do I Hook It Up? Dyin Over Here !
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
to begin i have a two wire tachometer hand held, i need to adjust the idle (inside tachometer deffinitly isnt reliable) one wire is possitive one negative obviously...
i tried the wire from the distributor to coil, but it wont start with that connection, i tried all four wires to the ignition coil unless im doing something wrong? im not sure i need serious help on this plz help me !
2.8L v6 firebird 1988
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Hand Held Tachometer Where Do I Hook It Up? Dyin Over Here !
im not familiar with the ignition on a v6 car, but on the dizzy should be a small wire, probably brown, that is the tach signal, you should be attaching to that wire. Its probably on a plug all by itself.
Axle/Gears: 10 Bolt
ive traced the oe tachometer and it hooks to a blk/white primary wire on the coil, but when i hook my positive to the coil where do i plug the ground? tried it on my hand held tach, no reading..im stumped
manual says white goes to instrumental cluster panel, blk thick spark plug wire goes to distributor and is linked to coil ground? i guess the coil is a ground? pnk wire goes to hot at all times fuse, other pink goes to radio noise capacitor.
ground should be the chassis, no? Just attach it to the chassis somewhere, or a bolt on the engine
Car: 83 Camaro
Engine: 383
Axle/Gears: 4th gen 10 bolt 3:42 POSI
Car: 2010 Camaro 2SS, 1994 Chevy Blazer
Engine: 6.2L, 355TBI
Axle/Gears: 3.42 posi, 3.73
I think the positive on the tach would go to 12V (any 12V), and the ground would go to the negative on the coil (black w/white?). My hand held tach has power, ground, and another wire that goes to the negative on the coil.
I have the wiring diagram for the 2.8 if you need it, let me know.
Randy
after all the tach hookup is always the negative side of a coil. If I can remember, my 88 2.8 was a white wire on the remote coil(coil has 2 connectors that mesh together, one conn goes to the dizzy and one goes to the main harness, and the main one has the white wire that the factory tach triggers off of.)
hope this make sense....
Randy
Car: 83 Camaro
Engine: 383
On an after market TACH Green same as above, white to dimmer switch, black to ground and red to batery voltage when ignition is in on position.
Axle/Gears: 10 Bolt
My tachometer only has two wires, one with a black boot and one with a aligator clip.
the external ignition coil has 4 wires + the black distributor wire the spark plug lookin one.
theres a black wire which connects to a white wire and goes into the coil, thats the in car tachometer power wire, according to the book which is correct because if i disconnect it i get nothing in the car. then theres a blk wire with pnk stripe, and on the other side theres a wire that goes to the fuse box, and one going toward the ignition module.
if i disconnect the tach wire and plug my aligator clip there where do i plug the boot wire?
ive tried the chassy, i get 12-14 volts but no RPM's on the tach, see i have a tach/dwell/volts, and the tach works used it on my other vehicle.
i believe its because its getting double grounded i cant figure this one out.
Axle/Gears: 10 Bolt
Randy
Randy
pink====????
white====black/white?
so, just hook up your 2 wire tach to the pink and white. if it does not work, reverse the connections. other than that tell me what brand the handheld is
so I can try to find some info on it.
Randy
Axle/Gears: 10 Bolt
Blk/White is the tach wire, and the blk with pnk stripe is shown in the manual somehow connecting like this blk/white<--|
| coil
blk/pnk wire(which this wire then leads to ignition module.)
so thats the first connector. ill try what u said tommorow morning, in the manual it practicly shows the whole ignition coil is a ground.
my tach is a Tachometer/Dwell/Volts Meter Sears brand thats all it says, big black box not too big, has a booted wire and non booted aligator clip. (old) bout 6 years got it for 100 bucks)
thanks alot Randy and others !!!!!!!!!!!!!
| coil
| coil
| coil
makes sense doesn't it.
Car: 83 Camaro
Engine: 383
I have the same one and the first post i replied is correct for that tach.
Make sure it is set to RPM. look on page 5 and 6 of the manual for connections to different coil types. The black goes to engine ground or negative on the battery.
Axle/Gears: 10 Bolt
blk/white = tach wire
blk/pink=ignition module wire
others=fuse box and radio capacitor/module
so where do i hook it up?
Axle/Gears: 10 Bolt
second coil, i hooked the aligator clip wire there, and the booted wire to neg term and got nothing... need to make jumpers were im totally confused..
the second coil is my coil, i hook the green wire where u stated because that is the tach wire, so were do i make jumper?
Car: 83 Camaro
Engine: 383
this is my last post on this one. the green wire goes where i showed and the black goes to a good vehicle ground. best being the negative terminal of the battery. the jumper is only so you can have the original tach wire and your tach wire both hooked up. if you have it hooked up this way, start the car and get no reading the 5 year old tester is broke, i know mine is shot and gave me a lot of false readings. Good Luck
Axle/Gears: 10 Bolt
thanks alot cooter ill give it a shot.
