what cam should i go with for my 355 build
Car: 86 z28
Engine: 355 113 heads ported HSR hot cam
Transmission: th350
Axle/Gears: 7.5 342
im building a new 355 motor with speed pro flat top pistons.10.5 c. vette 113 ported heads.. not sure what cam to go with i was thinking hot cam or zz4 cam. but i think the cc503 seems like a better cam.. this will be on stock ported tpi set for now... but hsr latter on... 700r4 trans with 2200 stall and 342 gears. street car.. lite track.
Re: what cam should i go with for my 355 build
with hsr and xr276hr cam i can say you can hit low 13's to high 12's with a good exhaust i think the part number is 8-503-8 from comp cam id step up the stall a bit to ab 3000 with this cam fora car mainly for the street but u can run the 2200 stall....just wont preform as well but still a good motor
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
XE274 would be my vote, or maybe the GM#847 if you want to use a GM cam.
dude, go to compcams and download a program called camquest for free! u can play with your options, before and after, and see what cam is best for your application. try it out, its very helpful.
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
cool thanks.. i want a nice cam but not to much i dont want to run a 3000 stall.. converter.
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
i went with the gm hot cam because. i found a real good deal on one. im on a buget.. next thing my vette 113 heads have pushrod guide plates.. so i can run normal roller rockers right...
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
the hot cam was a good deal. im running stock tpi for now.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Personally I'd go w/ the 503. It is a better cam w/ better technology than the older style Hotcam. If you have long term goals to get a HSR then get the cam you want for that.
That's what I did. I ran the stock TPI w/ my 227/233 cam for a long time before I just installed the HSR. The car ran fine w/ the TPI and went 13.4 @ 102 w/ the stock TPI a cam that was way to big. Now it will be time to see it pay off!
Car: 86 z28
Transmission: th350
Axle/Gears: 7.5 342
when i do the HSR i will change cams its just a street car for now. so im trying to stay mild build 350 hp or so if go big i would build a stroker motor.and run a carb. and long tube headers... but thats down the road.
i will problay pick up a nother camaro..
Car: 87 Iroc 5.7 /86 Trans am
Engine: 5.7 TPI / 350 carb
I have a 355 with a street avenger carb (holley 770 cfm), comp cams xe230/236 cam .490 lift and 10.75-1 compression
works great in my cruiser
ambainb
04-25-2016 09:21 PM
355tpipickup
Alternative Port EFI Intakes
08-29-2015 10:47 PM
