How much should EGR diaphragm move?
Before I begin, I wanted to let you guys know that I did indeed read-up on EGR and code 32 topics in the forums. In my daily driver 92 LB9 5spd TA every once in a while, like no more than once a week, I will get a code 32. I turn off the car, start it again, and it goes away.
I read the article "lowdown on code 32". I am getting ported vacuum to the egr, and i know the passages in the intake/heads aren't clogged because I just had the intake off a couple of months ago. I let the car get to OT, removed the throttle bracket on the plenum, covered my hand with a sock so i wouldn't burn myself, and managed to get my index finger to touch the underlying diaphragm of the egr valve, revved the engine, and it definitely moves... no more than 1/8 inch or so. It holds position until I drop it back to idle. Does this seem like proper function?
I'm 4500 ft. elevation here in Reno, could that be a factor? Also, I am running a 180deg thermostat with appropriate fan switch, and stock PROM... could that be causing the occasional code 32? Any input would be much appreciated.
Re: How much should EGR diaphragm move?
I'm not the resident EGR expert but the valves I've messed around with seem to have more travel than that- maybe almost 1/2". Don't recall ever messing with a TPI EGR valve specifically, though.
sailtexas186548
02-17-2017 03:07 PM
