possible stupid throttle question
Car: 88 GTA
Transmission: Manual
So yesterday I noticed that when the gas pedal is fully depressed, the throttle blades aren't fully opened. Am I correct in assuming that the throttle blades should be sitting completely horizontal? They seem to be angling up about 20 degrees from horizontal. I'm assuming this would be slack in the cable, can the cable be adjusted in our cars, or is it strictly a replacement item?
Also would that 20 degrees or so from being wide open be much of a hinderance to top end performance?
Car: 1986 Corvette, 1985 Z28
Engine: 383 Vortec HSR, 350 Vortec TPI
Transmission: 700-R4
Axle/Gears: 3.83
Re: possible stupid throttle question
Does there appear to be a power loss of any sort or is it normal? As far as I know, my 305 isn't completely horizontal, but I'd have to double check on that.
Car: 88 GTA
Well I havn't particularily noticed any loss. But I've also never thought to check the throttle plate before with the pedal floored, so it could have been like this as long as I've had the car. You'd think it would be designed to have the plates open as much as possible.
Car: 88' Camaro IROC-Z
Engine: 383ci TPI
Axle/Gears: stock
Depressed means pushed down.
an exerpt from the dictionary:
de·pressed adj
de·pressed adj
- Lower in amount, degree, or position
Car: 88 GTA
I know the butterflies go horizontal, but should they be completely horizontal? Because mine arnt, they are angled up about 20 degrees from horizontal. Wanting to know if this is normal or if its time to buy a new throttle cable.
