Glyptal seal??
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
Glyptal seal??
Hey does anyone know what glyptol seal is used for in the lifter valley or wherever else its used in an engine, why its used, pros, cons?!?!?!? I'm probably gunna buy a bare block 350 and it has that in it.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Glyptal seal??
It keeps oil from sticking to the lifter valley walls so it drains back to the pan. There are less expensive ways to accomplish the same thing.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Glyptal seal??
It's electric motor paint. It seals the casting so you don't leech crap out of the iron, and more importantly to help the oil flow faster/easier.
Cons? Price of doing it I guess, the stuff isn't all that cheap.
Engine: 5.7 LSX
Re: Glyptal seal??
wow nice! so if its not cheap then i'm getting a pretty good deal! thanks guys!
Re: Glyptal seal??
www.glyptal.com
Yeah that stuff is HIGH $$$$$! Back when I worked at a place that distributed it and similar product lines, the particular part # that got permanently enshrined as holy in hot-rod folklore after it appeared in some one of the "how-to" books, sold for about $30 a gallon. Probably twice that now if not more. Although we sold to professional users, namely electric motor rewinders, so we didn't sell too many gallons; mostly drums. Probably costs $3, maybe even $5, to use it on a block.
As said though, it's not particularly special, as far as being "different" or "better" than using anything else for that purpose. Regular rattle-can engine paint works just as well.
Car: 1982 Trans-Am
Re: Glyptal seal??
FWIW - I used red rustoleum aka Tremclad. Brushed on, after primer IIRC. It's still there after 1000miles and another teardown.
1Aauto
Sponsored Vendors
10-19-2016 09:50 AM
1Aauto
Sponsored Vendors
10-13-2015 04:06 PM
