Need little help
Car: 1991 Camaro RS
Engine: 305 TBI
Need little help
kinda feel bad by making this my first post...
well i have a 91 camaro RS w/ 305 TBI automatic w/ 128k miles
just bought it,and when it sits for awhile....i go to crank it and it starts and soon as it does it bogs down and the lights go dim,like its goign to shut off/stall.....and it bounces between 0-600 rpms....it trys very hard to keep it self up but then finally dies......then if i try to put in drive and take off it bucks,like its not getting anuff gas.....but if i hold the gas down so it idles at bout 2000rpms for bout 1 1/2 or 2...it will drop back and idle at 650 like it should then it runs great......also its runs cooler then it seems like it should,so belive it has lower thermostat,as in its runing little over a quater of the guage it is a very nice car and the engine is sound...im thinking fuel pump
what yall think?
what yall think?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Need little help
Have you tried the usual tune-up things first? Fuel filter, IAC, PCV, etc.?
P.S. All glory to the HypnoToad.
Car: 1991 Camaro RS
Engine: 305 TBI
no,havent done anything yet.....tryin to figure it out before start buying things it doesnt need
Engine: 383 Carb
Transmission: 4L60
Those are maintenance items that need to be done, unless you have a good idea that they were recently done by the previous owner. They might not fix your problem, but at least you'll know what you're dealing with. Is it setting any codes?
