Sucidal car, any ideas?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Ok latley i've been fighting to get my car to run correctly, i keep having a random jerk when i either a) get on it...or b) try to accelarate in 4th or 5th, so i had my neighbor whos a master technician come look and we've been knocking out the possible issues 1 by one, first the filter, pump, FP reg, etc.
About the time this jerk developed my car would idle like its trying to kill itself, drop to 500, then rev up to 1500, back and forth and its horrible, sometimes it gets slow enough to where you can see the teeth on the belt clearly. He said i could have a vaccum leak or my map sensor is going out, hes giving me a sensor for free but i still want to kill the problem, anyone have a good way to check for vaccum leaks? And could a vaccum leak or bad sensor cause my described issue?
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
Re: Sucidal car, any ideas?
i would check for vacuum leaks. i have had similar symptoms in a mustang and the cause was a vacuum leak.
i dont know much as far as manifold air pressure sensors go, but i am sure somebody else will chime in on that.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
anybody? im stuck here, this is my dd and that jerk + arizona drivers is testing my nerves lol
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
is it throwing any codes ? for finding vaccum leaks i use a can of carb cleaner and spray it around the vaccum lines while motor is running and listen for the rpms to change, usually get you close to finding a rotted or broken line.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
codes was my first thought and the paperclip trick got nothin. I do the same thing with the carb cleaner but i havent gotten anything, anyone know where i can fiond a diagram of vaccum lines so i can trace them?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
it's done! i got it! it was the MAP sensor......and i was chasing my fuel system down....oh well $300 later i know i can count on my fuel for a while lol
db057
08-11-2015 10:11 PM
