DIS...
Car: 1989 Camaro RS
Engine: 2.8l v6
Transmission: 5 Speed Manual
Axle/Gears: Probably the stock 3.42
DIS...
What do I need to put a DIS system on a 1988 305? I saw a ignition control for DIS that was from MSD but what else do I need, and how do I do it? Thanks.
Re: DIS...
You'd need the same thing ANY motor needs.
A crank position sensor, a cam position sensor, a set of coil packs, and a computer that can produce the correct signals to fire the correct coils at the correct times.
I could be wrong (well I AM wrong, but besides just that, mistaken), but I don't think being a 305 has much to do with that.
Car: 1989 Camaro RS
Engine: 2.8l v6
Re: DIS...
well yes I know that...i just figured people dont think its worth doing anything to a 305 so they would not answer...anyways...
Where can I get that stuff? what ECU could I use? Comander 950, FAST XFI, LS1/LS6? I am trying to free up as much horsepower as I can by removing as much friction as possible...
Re: DIS...
Yes, lots of ECMs will support DIS. Not sure about the Holley, but I kind of don't think so; FAST, yes; stock ECMs for LS motors, of course, but that would be rather a pain to retrofit, with the multiple 02 sensors and all of whatever else; the newer Accel does, IIRC; Big Stuff has a model; no doubt there are others.
Car: 1986 IROC
Engine: 355" TPI
Car: 1989 Camaro RS
Engine: 2.8l v6
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: DIS...
If you thoroughly enjoy spending much of your time troubleshooting phantom problems, then yea, that could be the "benefit".
IIRC "DIS" is the bane of many 4th gen owners existence. Far from a "great" item.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: DIS...
You won't lose any friction by changing, because the cam sensor would probably go in the same location the distributor used to be in. But theres no drag there anyway, like there is at say - the water pump, or alternator.
Car: 1989 Camaro RS
Engine: 2.8l v6
Re: DIS...
Thanks for the info... sounds like a pain in the ***...about the water pump and alternator, I am gonna take off the smog pump, power steering, and get a electric motor to run the water pump...I am gonna keep the a/c, because its florida and its hot here... I just gotta figure out how to set everyhting up, in the future i am going to put in a D1SC with an intercooler...
