Which Distibutor to use?
Car: 83Z28 HO
Transmission: G Force 5 speed
Magna Charger claims both large cap HEI distributors I have won't fit with their blower.
-So I'm looking for one that will fit.
Are there any small cap type distributors that will plug right in to my stock HEI connector on a '83Z? (the 3 pin type?) - I'm not on the CCC computer anymore, so I need both a mech/vac advance.
Only one I've seen that's promising is a Mallory Unilite.....but it seems there should be more out there. Not trying to break the bank either - I'll be using a MSD boost retard with it. (PN 5462)....
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
There are many available. Search www.summitracing.com, MSD 8361 and Summit's 850055 are two examples that require a box.
Car: 83Z28 HO
Re: Which Distibutor to use?
-If you're SURE the base and cap are smaller, I'll order the Summit one!!...
Engine: LS1/LQ4
I know you can't always trust Summit's pictures, but I have the 8361. It definitely is small cap. It plugs directly into MSD boxes like Digital 6 and 6AL. I believe that applies to the 5462 as well, from what I can gather from the instructions (http://static.summitracing.com/globa...2_frm23950.pdf , Fig 4).
Car: 83Z28 HO
Exactly what I needed to know! I'm leaning towards the Summit 850055 that you kindly posted.....seems to have everything the MSD does but cheaper.
I have a practically new MSD 8362 that I can't use...
- Just another sacrifice to the blower gods....
drain89
11-10-2003 02:42 PM
