Failed Smog New Engine?
Reposting from TPI forum.
So my Camaro has struggled to pass the last 4 smog inspections and failed the last two in So Cal. I am tired of going through this. I have 117,000 miles on it. No fluid leaks of any kind. Probabaly have a vacuum leak under the dash related to my vents because I can hear a hiss. Other than that, my Camaro is in immaculate condition, outside, inside, underneath the hood. It has not been a daily driver since around 1998. I will never sell it, and when I die, I have asked my wife to bury me in it. I put around 200 miles a year in it. Please see my list of mods below.
Because I love still love my car, Im thinking about just throwing in a new engine and high flow cats. I would like to keep my Camaro TPI and smog legal, but Im not sure how to go about this, what is compatible, and maybe upgrading a little. I will have someone do the work as I dont have time. Currently my car is at the Chevy dealer where a friend works and will be looking at it. Should I look into a crate engine? What will fit? Should I be looking at just a block and heads? Not sure about budget either. I guess right now I can plan on a budget of 1-4K maybe 5K. Just not sure at this point. What is my best bang for my buck, a 383? A rebuilt? Although Ive never been one to buy used or rebuilt. Am I wasting my money? Dealer can be very pricey, is there a better shop that knows what they are doing? Im really looking for some guidance. Im reading Camaro performance books now and the net to help educate me some more. Lots to think about. Other recommendation?
Some pictures of what my engine bay looks like now.
Sorry for the many questions and thanks in advance for your patience and help!
Happy Holidays!
http://f03-f01.mypicturetown.com/P2P...htiQa/item.jpg
http://f03-f01.mypicturetown.com/P2P...%25P0/item.jpg
Happy Holidays!
Re: Failed Smog New Engine?
Hi, thanks for the reply. I'm in Sunland area. Burbank, Universal City, Glendale are nearby cities. My car is currently at Bubank Community Chevy. Basically I'm in what's considered the San Fernando Valley area. I'll have to get the smog numbers as I left the report in the car for my friend to look at. Do you own a shop nearby? Also where did you move the thread to so I can go there. I had originally posted it in the TPI forum but then found the Engine Swap forum, sorry if that was no no.
Starting to feel like I really don't know what I've been doing all this time...
Car: 1987 Camaro
Engine: 5.7
also might try running seafoam through the intake....IF that doesnt work the denatured alcohol trick worked for my bro.
So you dont live to far from me. Take your car to Kevin, he can really help you out, and he is not that far away.
We're in Orange near the Arrowhead Pond and Angel Stadium. Its my father's shop, Dyno Don. He does the engines and I do the computer tuning.
See the SoCal forum here. The info is in the sticky at the top about "SoCal Thirdgen Friendly Companies." Or just send me a PM/email.
willing to make the drive, I can take my little girls to Disneyland while I'm at it.
So...here are the smog #'s.
Keep in mind too that everything on my car is smog legal and I think I hear a small vacuumm leak somewhere under the dash where the a/c vents are.
Thanks for the help Kevin.
http://f03-f01.mypicturetown.com/P2P...T5PQg/item.jpg
Ok, high NOx usually means your EGR valve isnt working. If you do have a bad vacuum line, that will affect the EGR's function. But under the dash that would only affect your a/c and heater controls. It shouldnt affect the vacuum to the engine but anything is possible.
I will call you later today or tomorrow to talk to you more in depth and the possibility of bringing my car over to your shop.
Thanks again for all the help!
Oscar.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Some EGR solenoids have a filter, if the filter becomes clogged, the vacuum cannot bleed off properly and too strong of a signal will be sent to the valve. Causing the EGR valve to open too much and cause a driveability problem.
Not all EGR valves used on our cars are same, so make sure you have the correct type for your model.
Update -
My friend just called me, he said the EGR is good and the solenoid is also good. He said that I don't have enough backpressure and that is causing the EGR to not open (some of this is above my head). That I don't have enough vacuumm to make the EGR work? I quote, "the vacuum is fighting against the backpressue". I may have not gotten that right. They plugged one side of the muffler and on the other side they put a socket held with a clamp and when they ran it, "the EGR opened all the way and the readings" he said, "went way down to like 200". He suggested maybe putting in a smaller muffler. Further more he said, maybe my headers could be the problem? A little confused by this since SLP reccommends the 1 3/4" ones and that's what I had installed. So then it seems to me that installing high flow cats would make matters worse. I have to admit, I'm somewhat skeptical of the final analysis. My logical senses don't quite give me that warm fuzzy feeling.
This is somewhat beyond my comprehension. Does this make sense to anyone?
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: Update -
If it is not opening then is doesn't have the correct vacuum or the valve is not the right one.
Is it genuine GM, if not, that is the problem. After market ones are not good to use on our cars.
Re: Update -
Thanks for clearing up about the back pressure. It was somewhat disheartning to hear that my current mods we're causing a negative effect since I want to gain more power anyways.
I left you a voicemail at your shop and emailed Kevin about doing somework for me but haven't heard back. I understand your probably really busy.
thanks and Happy Holidays.
