i have a 1987 buick electra park avenue with a 3.8 sfi
Car: 1992 Pontiac Firebird Formula
Engine: 5.0 305 tpi
Transmission: T5 (5 Speed) lol
Axle/Gears: stock posi
i have a problem with a 3.8 like the one in the Turbo Trans am
i have a 1987 buick electra park avenue and my problem is my fuel injectors constently stay on.flooding the engine and coming outa the air box it has a new fuel pressure regulator, ECM, crank sensor, i checked the wiring harness for the fuel injectors fine no splices or meshing i suspect it could be the PROM in the ECM. But the reason i need this fixed very fast is because winter is knocking at my door in illinois and my 1992 Firebird Formula is fun in the winter but i like to put her away yes i do have a third gen im just asking if any1 is familiar with a problem like this in a in a 3.8 if you know anything drop me a line you have no idea how much i will appreciate it
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: i have a 1987 buick electra park avenue with a 3.8 sfi
That's basically the same 3.8L as in a 1987 TTA, (minus the turbo). Edit your post to say that's the car, and it won't get locked - hint hint.
I had a 1987 Delta 88 (same car, different tag on the front), but it never had any weird problems like that.
You might find some help here;
http://www.automotiveforums.com/vbul...play.php?f=105
Engine: 5.0 305 tpi
Re: have a problem with a 3.8 like the one in the Turbo Trans am
so what your saying is i can only talk about third gens here nothing else? i mean im ok with that but i need 2 see if any1 else had a problem like this 1
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
If someone wants to PM you, that's fine. But, this Board is for discussion of third gen f-body tech issues only. Can't disguise that engine as anything f-body.
RedLeader289
05-28-2019 01:47 PM
darwinprice
17
10-11-2015 11:51 PM
