89 Camaro RS 2.8
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: 89 Camaro RS 2.8
IIRC the cars switched to SD with the 3.1, so yours would have a MAF sensor, not a MAP sensor.
Well i had it hooked up to a computer today and it came up with a bad coolant sensor, a bad throttle position sensor, a bad vechile speed sensor, egr failure, bad ESC, and a rich oxygen sensor. I don't know what would make all of them sensors go bad like that but i had the ECM computer replaced today and it didn't fix the problem. So i am so lost.
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
Well i had it hooked up to a computer today and it came up with a bad coolant sensor, a bad throttle position sensor, a bad vehicle speed sensor, egr failure, bad ESC, and a rich oxygen sensor. I don't know what would make all of them sensors go bad like that but i had the ECM computer replaced today and it didn't fix the problem. So i am so lost.
