how do i reduce the delay between foot down and go with auto?
Old 11-09-2007 | 11:20 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
im not sure if this is in the engine or tranny so if it dont belong here please move it, basically i was just wondering how to reduce the delay when you slam the pedal anyone know what im talkin about? its when you put the pedal down there is a delay before it takes off i hope that makes sense
Old 11-09-2007 | 11:23 PM
Rocket-Doc's Avatar
Car: 1990 RS/SS modified
Engine: 355ci, 113 heads, LT4 hotcam
Axle/Gears: 3.73 Eaton posi
Re: how do i reduce the delay between foot down and go with auto?
corvette servo and spring would help...
Old 11-09-2007 | 11:45 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
is that a fuel injected motor ,it sounds like a hesittation to me. my tpi would do that until i cleaned the throttle blades a body
Old 11-10-2007 | 01:07 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
give it a good cleaning in the throttle to make sure its not sticking. make sure its tuned good and not hesitating because of poor ignition or a overly rich condition
also aluminum lightweight underdrive pullies help let the motor rev up, basically giving you better throttle response
higher stall converter will help too
Old 11-10-2007 | 01:25 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
I think it's the nature of the auto beast honestly. There's a company in cali called level10 transmissions that can build you a killer fast tranny... or so I've heard. Corvette servo? All that other stuff? I don't know what that means. But I sure would like to. - as far as a dirty throttle body, man that would have to be a heck of alot of carbon to stand in the way of the throttle opening all the way when your foot mashes down that pedal.
Old 11-10-2007 | 06:15 AM
Brennan's Avatar
it is a carburated engine and theres nothign dirty becasue its the same in EVERY car my 2006 silverado is like it the only cars i find dont do it is manuel tranny cars i dunno why its like it or what purpose it would serve but i hate it im an impatient guy
Old 11-10-2007 | 10:36 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
ive had a few carbed small blocks and never a manual trans but when ever i had a hesitation it was always the carb adjustment or something tweaked with the ignition. For your info a very small lip of cake behind that blade will cause alot more off idle hesitation than you think. if you havent scrubed down the carb in the last 10k it probaly needs it.check your fuel filter.unless your motor is reving from the second you start on the gas(before you hit the floor) i would look into air and fuel
Old 11-10-2007 | 11:40 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
idk my car seems to go hard when i stomp on it, but its not an INSTANT downshift sometimes. but that stall and underdrive pullies get that motor instantly revved up before it shifts
Old 11-10-2007 | 10:36 PM
Brennan's Avatar
ok maybe i should clarify the question abit it dosent happen when im just starting to move or anythinig or reving the engine, im talking about 60-ish km/ph it happens, i punch it to pass or something and the car slows a bit then it goes normal i think this maybe somthing in the tranny or tc but im not sure just wanting to al least reduce it, also my car has a shift kit if that would do anything i dont know the brand previous owner installed it. i think orr89rocz knows what im talking about
Old 11-24-2007 | 11:26 AM
Engine: 3.1 V6 MFI
hell, pour some lucas tranny fix in it, it makes a heck of a difference.
Old 11-24-2007 | 12:10 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
After my trans go install from Pro Built, my downshifts are much harder and faster.
Old 11-24-2007 | 01:53 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Get a manual. Flat out lol i hated that crap in my cars, Had it in my 81 silverado, my parents trucks still do it, my brothers lancer, everything, unless its stick shift. The ONLY thing i've seen not do it, is my buddies 87 rx7 TII that he mocked 2 turbos onto, but thats because of the 2 turbos and i'm used to waitint for them to spool in any car so you dont notice
Old 11-24-2007 | 04:03 PM
Engine: 3.1 V6 MFI
I've had new cars, fast cars and old cars - I have to agree that the only way to stop that delay is with a manual. Auto tranny's seem to have to think about what's happening for a half second once the throttle opens up all the way. It's not broken, that's just how it is. Information can only travel so fast, so the completly mechanical manual tranny will always start faster.
Old 11-24-2007 | 05:13 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The trans shouldnt cause the lag unless its slipping. How does the motor behave? Does it just sit there after you hit the gas, or does it act like its revving in neutral before it goes?
FWIW, with an early car without an electronic throttle or any garbage to reduce the torque output on tip in, it should go instantly (or at least spin the tires) regardless of whether its an auto or a manual when you stab the gas.
Old 11-24-2007 | 06:23 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
My car does the same thing. Kick down is painfully slow. I know its not engine hesitation because if I hold it in second gear then smash the pedal its an instant kick in the ***. If I let it upshift to third or 4th then mash the pedal I can hear my engine instantly rev up against the converter but the car doesn't go anywhere. It takes the transmission about a full second "grab" second gear like it should, then it starts pulling.
Old 11-24-2007 | 09:57 PM
Brennan's Avatar
exactly what im alking about
Old 11-25-2007 | 08:39 AM
Engine: 3.1 V6 MFI
Me too. Honestly, I've owned alot of cars. My camaro does this, my 2002 crown vic does this and did when it was new when I bought it in 02. My old mazda did it. I think it's just the way automatics are. Maybe not if you have a corvette or something with a performance auto tranny. I can hear my CAI suck in before I feel the go in any auto. When I had my probe and my storm (manual cars) The CAI's made that sucking noise, but it was at the exact same time the clutch grabbed, not a half second later. Brennan, I don't think your car is broken, if you want metter response from your tranny get a performance rebuild kit. A CAI or TB spacer may help throttle response and get you a little closer to your "goal of go" though...
Old 11-25-2007 | 05:35 PM
Brennan's Avatar
i know my car isnt broken i was just hoping there was a way to reduce the delay, i want a manual tranny so bad but thats not in my budget right now nor is a new car and as far as i know i have a shift kit not sure what kind the previous owner installed it. I wasnt looking for a fix maybe i should have said improvement
Old 11-25-2007 | 05:50 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
well the corvette servo would help a bit. The thing is the line pressure is low from stock and the car is meant to shift somewhat smooth from the factory. the vette servo increases pressure and lets it shift harder, that and a shift kit will help you out alot.
Old 11-25-2007 | 06:00 PM
poppn's Avatar
Car: '85 Firebird, '74 Nova
Engine: 2.8, 5.7
Transmission: T5, TH350
Axle/Gears: 3.42 open, 3.08 open
On my Nova with a th350, you can basically adjust when the tranny should kickdown depending on how far the throttle is open. I'm able to set it to downshift at something as little as 25% throttle or as much as 90% throttle, it's very convenient.
As far as the time it takes to finally drop a gear and go, it's basically about 0.5 to 1 second.
A good shift kit will also help in harder shifts/downshifts. Will get rid of the smooth painfully slow shifts and help your tranny last longer.
Old 11-25-2007 | 06:13 PM
Brennan's Avatar
my car shifts nice and hard but still has the delay with the downshift is there anything else other then a corvette servo?
Old 11-25-2007 | 07:30 PM
speedped79's Avatar
Car: 1982 z28
shift it manually
Old 11-25-2007 | 08:52 PM
poppn's Avatar
Engine: 2.8, 5.7
There will always be a delay, not much you can do about it.
It's the same as someone doing an easy downshift in a manual.
Old 11-25-2007 | 10:46 PM
Brennan's Avatar
so it looks like im screwed till i can pony up the dough to switch to a manual or get a new car ahh well when im finished school i will be a qualified electrician then money wont be such a big deal
Old 11-25-2007 | 11:08 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
Mine does this too man, sometimes it will go like no tommarow, others it just sits a second then takes off, its annoying, The lucas transmission stuff is good stuff though.
Old 11-25-2007 | 11:48 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Transgo shift kit along with new servo. With my old 700-R4 and a shift kit, it shifted instantly as soon as I stabbed the gas. I actually liked it better then my stick.
Old 11-26-2007 | 12:00 AM
Jassack's Avatar
Car: 1989 TA
Engine: 305, 5.0
Sorry to hear about it but i'm so glad i have a manual!
Old 11-26-2007 | 12:11 AM
Brennan's Avatar
is there a way to tell what kind of shift kit i have in my car or to see if i even have one because im just going by what this guy who sold it to me said and he told me a few things that turned out to be bs , it shifts nice and hard but seeing it would be better cuz if there isnt one there will be
Old 11-26-2007 | 12:35 AM
11sORbust's Avatar
Buy a good stall! They tend to apply power in proportion to throttle application. Very different feeling than a cheap $350 converter.Something with a STR of 2.5+ . I like to program E-transmissions to downshift as WOT is reached, not after. 700R4's have weights and springs (governer) that will effect shift points.... while the tightest (correct) TV cable adjustment will ensure fast downshifts.
Old 11-26-2007 | 01:57 AM
poppn's Avatar
Engine: 2.8, 5.7
i have a transgo kit in my Nova, barks second gear at 45mph at 50% throttle. nice HARD shift
Old 11-26-2007 | 02:59 PM
Garconer's Avatar
Car: 1986 Camaro
Engine: LG4 305 w/ Qjet
Axle/Gears: 2.73 10-bolt
It sounds like it could just be the lean spike when the secondaries first open,
bring the peddle down a bit more gradually and see if it does the same thing.
Old 11-26-2007 | 10:48 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Sounds like quadrajet bog to me. Happens when the secondary air valve opens too quickly rather than gradually like it should.
Two typical causes (sometimes both): 1) Choke pull-off (called "vacuum break" by the factory) leaks and releases too soon; 2) Air valve tension mis-adjusted, allows the AV to open too quickly.
There is a tech article linked from the thirdgen.org homepage "Tuning for Performance with your Computer-Controlled Quadrajet". There is also a sticky at the top of the Carburetor forum with a copy of the GM manual for the E4ME carb - goes over the AV adjustment procedure (and has pictures).
Linson
09-25-2021 08:55 PM
Hal87
Exterior Parts Wanted
11-08-2015 04:40 PM
gord327
10-03-2015 02:25 PM
Linson
10-01-2015 10:50 PM
Hal87
09-26-2015 10:26 PM
