need help fast??
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
need help fast??
idk wuts wrong. today i was puttin chrome vauvle covers on and i went to start the car and it would only run for a second and shut off. i tryed it a couple of times but still the same thing. so i went to the engine to see if i knocked anything out of whack but nothing. so i tryed again and starts for a second and dies. but wen i givin it gas it tryed to run but once i stop givin it gas it dies again. please help
Car: 86' Z28 Camaro
Re: need help fast??
i only worked on the passenger side of the car if that helps.idk wuts wrong im so upset
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Wuts rong is tat you didn't reconect evrything. CHK ur vacuuuum lines man!! Or ur spark pluug wires, thems too!~
Car: 86' Z28 Camaro
nope i go it its all fixed my egr vauvle was loose, i just have to replace the gaskets.
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Leaking EGR = Vacuum leak, I win! :-D
Just messin, good job!
sreZ28
10-22-2015 08:21 AM
