rubber rings on MSD distributor? need them?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I have these little rubber rings on the bottom of my MSD distributor...well one of them broke...what are they for and do I need them? Can I put it back in with the broken one missing?
![](http://i147.photobucket.com/albums/r295/wishmaster8/IMG_1884.jpg)
1 Post
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Re: rubber rings on MSD distributor? need them?
I dont know anything about distrubutors, but my guess would be that they keep the oil from pissing out.
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
Take them off, in the MSD directions, it say if the block has been chamfered to use them, if not however, they will be cut installing it. I tried using them without chamfering and mine looked the same way once I took it out. I never seen any difference in oil pressure with or without them.
ok....but what the hell is "block chamfered" how do i know or can tell if my block has had that or not?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The chamfering is a slight tapering of the edges of the distributor hole in the block so that there's no sharp corner there anymore to tear the O rings apart when you install the distributor.
yeah I did that...but what if I leave them in? what will that do?
like what does it do if you have them in a un-modified block anxd vise versa
what the point of the ring?
Engine: 383 Carb
Transmission: 4L60
If you leave them on, they'll just get torn up again when you install the distributor, unless you modified the block.
Some people use O rings should be used to stop the miniscule amount of pressurized oil that leaks around the distributor shaft. On the other hand, some people say that oil is necessary for lubricating the distributor gear, and actually grove the distributor to increase the amount of oil there. In practice, neither really seems to be necessary.
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
billet, block, chamfer, distibutor, distributer, distributor, distrubitor, engine, msd, orings, ring, rings, rubber
