cam opinion?
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
cam opinion?
for this winter i want to change my cam. what would be the best cam for my set up?
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: cam opion?
Follow me to the dark side.... Solid flat tappet, Isky Z-25, or even Z-27.
Re: cam opion?
hard to go wrong with a Isky cam. You have everything you need to step up to a Isky Z-27 cam. Exhaust needs work thou.
Steve87iroc is getting great results with this cam in his motor. The modest reasonable net valve lift is nice as the valvetrain will last and last and last.
Your heads are no the "twisted wedge" heads right?
Re: cam opion?
here it what i was looking at http://store.summitracing.com/partde...3&autoview=sku
Re: cam opion?
where can i get that cam or a link to the spec of the z27
Car: 1982 Trans-Am
Re: cam opion?
I typed "Z-27" into summit to find it, pretty easy...
http://store.summitracing.com/partde...7&autoview=sku
It's a straight pattern.
I wouldn't use a hydraulic cam when you get up to this size.
Re: cam opion?
i found it !what springs would i need for my heads?
Re: cam opion?
Re: cam opion?
A good bit more than you have now. with the new converter and some tweeking and tuning a solid 12sec performer.
You did not answer my question about your heads. it is critical.
Re: cam opinion?
they are not twisted wedge they are the new 195 62cc heads
Re: cam opinion?
i been thinking and want to go with the z 25. what kind power would in make?
Car: 1982 Trans-Am
Re: cam opinion?
It's hard to say. Really hard to throw a number out there.
More than what you have now is a safe bet.
Your Z-cam now is similar to the comp xe268H isn't it? That's exactly what i'm replacing with my Z-25
Re: cam opinion?
yes its about the same as the xe268h. is the solid lift cam streetable?
Car: 1982 Trans-Am
Re: cam opinion?
I think that solid cam is *barely* streetable.
It's quite aggressive. I'm not going to be driving mine through traffic or anything. I don't think i'll be needing a vacuum can for the brakes or anything though.
Mine is at my house now, waiting to be installed. Won't be driving it until may or so, so I can't tell you how it performs yet.
