Fuel cell to rear end clearance....
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Im concerned about the height and the rear hitting it on hard launches and bumps. I dont want to put it in the trunk space. Im looking at summit's 25x17x9 16 gal. Looks like it would leave about 4 inches from the top of the rear. Is this enough? I dont have soft springs, Im putting some moog's in that are stiffer than factory.
Car: 91 rs
Axle/Gears: 3.50 9"
Re: Fuel cell to rear end clearance....
TTT cmon im sure someone has done this.....
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
I picked up a cell second hand but it came from nastyperformance, they are not cheap but fit in the stock location, and have a sump w/-10 outlets...also accomodate the stock pump/sender.
http://www.nastyperformance.com/default.html
Ed quay race cars also sells a fuel cell for street 82-92 camaro`s
http://edquay.com/camaro/82-92camaro_catalog.pdf
Car: 91 rs
Axle/Gears: 3.50 9"
I think im giving up on the fuel cell, i need to get this damn thing on the road. Just going to hack out the old lines and weld in bigger ones. that way I can fill it from outside the vehicle. And its free. No mounting hassles.
Did you have to make any changes to use the Nasty Performance tank? They only list that tank for the 4th gen cars, but I wouldn't expect it to be much different since the 4th gen has the same rear suspension system.
Does the tank accept a factory-style neck or is it intended to be filled from the top (through the car) like most fuel cells?
Nasty is a good word for their company, that price tag IS rather nasty.
hectre13
12-11-2023 08:14 AM
hectre13
08-26-2015 08:17 AM
AkDrifted
08-17-2015 07:45 PM
