Vortec heads,performer rpm gasket question!
Hey, I am using gmpp vortec heads and a performer rpm vortec intake, i ordered "vortec" head gaskets from summit, and they where off. Im on a tight budget, and i cant be ordering parts and having them be wrong any more, Will eddelbrocks gaskets for the performer rpm work? I know they have the E-tec so it may be different. What gaskets are you using?
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Vortec heads,performer rpm gasket question!
what do you mean you ordered vortec head gaskets? intake gaskets? how where they off?
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Use the felpro composite gaskets meant for use with the stock vortecs and tighten the intake bolts to 11 ft-lbs. Most autoparts stores carry them. Ive used these without issue with my vortec RPM airgap manifold. Ive found that with the paper ones the intake bows somewhat under the higher loads needed to compress the paper ones and causes slight leaks.
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
get the felpro ones for like a 98 K1500.. worked great for me..
felpro #1255
Stock Vortec gaskets here. Hard plastic with the rubber o-ring inserts around the various ports. 12 ft/lbs max, as was mentioned above (think: screwdriver-tight). Just enough to flatten the o-rings, and no more (becuase it won't seal any better if you tighten further and you could crack the hard plastic and CAUSE leaks).
84z96L31vortec
08-20-2017 12:16 AM
84z96L31vortec
08-10-2015 08:27 PM
