large or small journals
1 Post
Car: 89 iroc
Engine: 355 TPI FINALLY
Transmission: 700r4/ SHIFT KIT
I'm trying to find bearings and see a lot of for large journals..
crank shaft
I have an 88 5.7 large or small, the bearings say std. so I'm not concerned about that.
crank shaft
1 Post
Car: 89 iroc
Re: large or small journals
is the stock crank a large journal for the main bearings?
this was copied from ebay
Part #: MS909P
Brand: Clevite 77
Condition: Brand new and in the box first line product.
This auction is for a brand new set of eight, Clevite 77 P Series stock replacement style main bearings for large journal sb Chevy engines. They are brand new and in the box, first line product!
Clevite 77 makes main bearings in numerous sizes. This auction is for a set of standard size rod bearings and fit large journal cranks in 1968 and newer small block Chevrolet 262, 265, 267, 302, 305, 307, 327, 350, 350 LT1 LT4, and 383 V8 engines.
just making sure these will fit.
Part #: MS909P
Brand: Clevite 77
Received 1,837 Likes
Small journals = ALL SBCs from 55 to 68, exc 67 & 68 350 (265, 283, 327)
Large journals = ALL SBCs from 69 to present except 400; and 67 & 68 350 (all those sizes you posted, in those years)
Note that "ALL SBCs from 69 to present except 400" includes ALL 350s.
This has nothing to do with how far the crank has been turned.
So yeah, you want the bearings that fit a 350, in whatever undersize your crank now is. Those are typically described as "large journal", because they're not "small journal" or "400 journal".
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Except when they're called "medium journal" to distinguish them from the "large journal" 400 and make things more confusing, kind of like "externally balanced".
gta892000
09-16-2015 12:37 AM
