cam question
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
cam question
whats the biggest cam that you can put in a 350 block with a 383 crank and using stock 5.7 rods and arp rod bolts without clearancing issues?? i currently run a .480 lift melling cam now and am thinking of upgrading. not sure if i damaged the one i have during break in period or not. the motor got pretty hot when i first got it together until i changed to a bigger radiator.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cam question
The only way to find out for sure is to try.
I had an XE268 in a 383 with stock rods and ARP bolts.
