Retro Roller Lifters
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Just need to know which way to put these in. Theres a link bar that connects to the top of the lifter. Not sure weather the link bar should be on the inside (more towards the lifter valley) or on the outside (closer to the heads).
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Retro Roller Lifters
You'll probably find that they only go in with the link bar towards the center. If the link bar is towards the outside it will rub against the block.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
yes and some of the link bar lifters also will have an Arrow showing which side of the linkbar should be up
KO1
16
10-15-2015 05:00 PM
skinny z
10-05-2015 06:23 PM
