hesitation when i step on the gas
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
k i'v read a bounch of threads on hesitation but nothing seems to meat my problem, i'v just put a 350 bored 30 thou in my 84 camaro i'm using a edlebrock rpm air gap intake, holly 600cfm 4160 vacum secondary carb, mallory HEI distributor, a summit 110 gph fuel pump. i'v checked timing, valves,carb settings, vacum leaks and nothing every time i step on the gas it sputters and hesitates really bad then aventrally takes off and is good. thanks jason
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: hesitation when i step on the gas
well i am just going through the same problem... did you set your float lvls? and your idle mixture with a vac. gauge? basically at this point you need more fuel how you accomplish that depends on a few different things
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
ya i set both of them, what do u mean by more fuel
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
i'v been told that i might be getting to much fuel would that make any sence, if so how do i set the carb so it dosen't get as much fuel
Chad Speier
09-24-2015 12:32 PM
