is 150hp really right for a 84 bird???
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: is 150hp really right for a 84 bird???
It drives like a 3300lb car with 240+ ftlbs of torque. Your 3300lb (insert other car here that has a staggering 150hp) probably has closer to 170ftlbs of torque, eg GM 3.1L V6 car for example. That's why it's lame, but your 150HP bird is "quick".
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
That's 150 "net" horsepower.
Not 150 as compared to the HP rating you see on crate engines.
Car: 1983 G20 Chevy
Transmission: 4L60
Around 210 at the flywheel. Mercruiser 305s that used the same long block in their boats, came in at 230 FWHP through a much less restrictive exhaust, better timing advance and fuel delivery, with no emissions restrictions.
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Why does this look like an '84 Firebird "Rock Crawler"?
I thought the Rock Crawler had more than 150 hp too...
Navy8125
Interior Parts Wanted
09-23-2015 01:11 PM
