Vacuum Question For The Experts
Running a '88 5.7 TPI. Did a vacuum check on it (hooked into the pvc hose) and it held steady at -19 but when i slowly opened the throttle to about 1500 rpm's the vacuum increased to -22 and held steady until I closed the throttle. Is this normal? I checked several repair manuals, and non of them made any referance to an increase in vacuum with increase of rpm's.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Normal.
The "pump" is moving more air at higher RPMs. With no load, the intake manifold vacuum will also go up.
mdtoren
08-16-2015 05:45 PM
