Fuel pump is groaning??
1 Post
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
My pump sounds like it is groaning, is that the sound it makes when its on its way out?? I do have the pressure kinda high, would that make it work harder and make noise? Its still the stock pump so anything is possible I guess, but the car is so low, I would hate to get stuck and have to get a tow.
Car: 1987 IROC-Z Camaro
Re: Fuel pump is groaning??
ok I thought this was just me...my story is a little more wierd though.......every 20 minutes or so my car will "moo" as my friends call it.......this is when the car is off and no keys in the ignition!
1 Post
Car: 91Z
Mine is making the noise while its running, not once it has been turned off. The only reason I could see it making noise once it has been off is from pressure bleeding off somewhere?!?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Yours was a different problem, and quite honestly didn't belong in this thread. So, the other thread was the right place to address it.
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
