ok to reuse these bolts?
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: ok to reuse these bolts?
Intake bolts are fine to re-use. Just clean 'em up.
Head bolts can be re-used as long as they're not torque to yield bolts. I don't believe 91's had TTY bolts. Check your manual. If it has just a straight torque value you can re-use them. If it says anything about torque + 1/4 turn or degrees of a turn, don't re-use them.
AFAIK, no Gen I SBC used a TTY head bolt, at least not stock. Not even BBCs used them, even on aluminum/aluminum engines. There are enough bolts in proper positions in SBC heads that they provive plenty of clamping force on any type head gasket, so TTY bolts are not necessary. Mr. Cole knew just what the heck he was doing.
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Clean up the threads like on a wire wheel, this ensures you reach your proper torque.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
ARP main bolts are only about $20, but head bolts are $80 last time I checked. I think that's at summit.
I re-used my stock bolts as well, FWIW. Make sure you use a non hardening teflon sealant on head and intake bolts eh?
Received 1,863 Likes
Right.... for a stock rebuild, if the head bolts are good, clean them up and re-use them. And the thing about the sealer is spot-on as well: in the SBC block, every head bolt hole goes RIGHT DIRECTLY INTO the water jacket. Use the Loctite "high-temp thread sealer", comes in a tube on a little card, you can get it at VatoZone and Advance and such as well as, no doubt, "real" parts stores. The center 4 intake bolts go into the crankcase and will leak oil if not sealed so do those as well; and since that stuff has Teflon, it makes a WONDERFUL thread lube, and will help keep from tearing up threads anywhere near water passages (where they often get all rusty), so use it on the other intake bolts and the water outlet bolts as well.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
http://store.summitracing.com/partde...9&autoview=sku
ARP is $60 now... They are like $40 when I bought mine.
http://store.summitracing.com/egnsea...=KeywordSearch
Next time I will go with studs though. You ever see those top fuel dragsters that the crew was putting on cylinder heads? They take a 1/2" impact and impact the bolt for 15 seconds, then get a breaker bar with a cheater bar and give it a half of turn extra.
Car: 86 Iroc
Engine: 383
Transmission: TH350
Axle/Gears: 3:73s!
yes but those top fuel dragsters have a little bit more cylinder pressure then anyone on this board has. On all of our engines that we build, we just use ARP bolts up to 14:1 compression, unless our customers ask for studs.
Car: GTA
Engine: 383 HSR
If the bolts are in good shape you can reuse them. When installing aluminum heads, it is often common practice to use washers with the bolts, and to dab some oil on the washers to get the most accurate torque reading.
Although, if you use the Teflon paste on the washers, it's nearly as good a lube; and it's a sealer TOO.
Saxondale
Exterior Parts Wanted
09-07-2015 06:11 PM
UltRoadWarrior9
09-02-2015 08:24 PM
