Engine Experts, Camshaft Button, why need one?
Old 07-30-2007 | 09:44 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
I'm trying to figure out how the camshaft would ever want to move towards the front. The gear geometry of the oil pump gear would suck the cam in. Is this a 9000 RPM closed throttle situation or something? Maybe if the engine starts backwards I suppose. What am I missing here in my logic?
Thanks!
Old 07-31-2007 | 12:29 AM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Roller lifters can't tolerate any axial motion. The distributor gear isn't enough to keep it back against the block.
Not needed with flat tappet lifters.
Old 07-31-2007 | 01:05 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Re: Engine Experts, Camshaft Button, why need one?
One piece rear main seal blocks use a cam retaining plate to do the job
a cam button does on earlier blocks.
Hey Moe, no wonder the water don't work...
these pipes is clogged up with wires.
Jerome Howard - 1936
Caspar
06-20-2016 12:19 AM
Reddeath210
10-06-2015 09:20 AM
smooth
08-18-2015 07:34 PM
Jake_92RS
08-17-2015 10:42 AM
bradleydeanuhl
08-12-2015 12:48 PM
