HVAC Dash Control - A/C Vacuum Leak?
Car: 89 Camaro RS, 79 Firebird Formula
89 RS v6 . There are two vacuum connections on the back of the dashboard control unit. The heater side works perfect. The a/c side (just two hoses) constantly hisses no matter where I set the controls to. I've taken it apart. put a little grease on the rubberized seal. Made sure everything held tight. Same thing. Tired of playing with it, I bought a brand new one from the dealer. Same problem!
Anyone know how to test it out, or knows how to fix it? Right now I just have it disconnected with a piece of tape across the two lines. All is well, just no a/c. Would be nice if it did work..
Car: '83 Firebird S/E
Engine: The Chevy 305. with carburator
Transmission: 700R-4
Re: HVAC Dash Control - A/C Vacuum Leak?
Are you sure it is the vacuum switch?
It very well could be the connector block that plugs into it.
Seth
Seth
I can try putting something non permanent like heavy grease on the connector maybe. Haven't tried that yet. Odd thou that just putting a little piece of tape across the vac connection seals it when it's unplugged from the switch.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I think that a new vac switch and properly mated vac lines would do the trick.
https://www.thirdgen.org/forums/atta...duct010707.jpg
JamesC
JamesC
In the picture, it would be the one hiding under the temp slider to the right. Will try to locate a replacement connector. Thanks!
