Finally getting a 92' Z28!
Car: 1992 Camaro Z28
Engine: 5.7 TPI L98
This weekend I'm buying a 92 z28 w/ the L98. I've always had a TBI and I just wanted to know what are some initial maintenance things I should do. I'm going to change the oil and have all the fluids flushed and refilled, but I didn't know of anything I should have done. Thanks.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Congratulations on the new car.
Depending upon the maintenance it's received, plugs, wires, cap, rotor.
Filters should all also be changed. And differential fluid (often neglected). Grease all fittings.
The rest depends upon its condition.
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Re: Finally getting a 92' Z28!
Whenever you buy a used car it's always a good idea to do the brakes or atleast look at them. You never know if the lines are shot ect. Having a fast car is cool, but it's always nice to be able to stop too
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
challenger71
09-10-2015 04:58 PM
MikkoV
09-09-2015 04:25 PM
