What does a MSD Digital Igition Box do?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: What does a MSD Digital Igition Box do?
On a stock engine, not much besides lighten your wallet.
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I had some idling issues. Nothing big, part of the problem is the cam they put into the motor. Anyway, i go the box as a gift (crane HI 6S) and the idle smoothed out and its not as erratic. The pull through the whole RPM range felt more smooth and improved. I thought it was worth it, but don't expect much.
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
It is a cdi box that makes the spark a bit stronger. Under 3000 RPM it also does multiple spark per ignition event.
So basically for a mild 350 it wouldnt do a whole lot for me? slightly better pull through the RPM Range?
I just see them all the time, and was wondering if they would be worth the 250 or so they cost.
The cheapest one will be probably the best. This kinda tells ya how much they are worth...
Go with crane HI6S. Its cheaper and does the same thing, plus it gives you the option to have the revv limiter, and it comes with the box, not as a pill and you don't have to buy any extra stuff.
Hotrodboba400
12-10-2019 07:07 PM
codeysabatini
11-10-2015 04:07 PM
sreZ28
10-22-2015 08:21 AM
86CamaroDan
09-29-2015 10:08 PM
