Can U use a gear drive on a Hyd roller motor?
Car: 1991 Chevrolet Camaro Z28
Transmission: Tremac T-56 6 Speed
Axle/Gears: 10 Bolt 3.73 POSI
Can i put a gear drive timing set on my 355 fully hyd roller?
Re: Can U use a gear drive on a Hyd roller motor?
Gear drives are available for the factory roller cam motors. If you're running fuel injection with a knock sensor, you don't want to use one though. The extra noise affects the knock sensor and caused the computer to retard the timing. If you're running a carb and no computer, go for it.
