building vortec heads
Old 07-12-2007, 02:07 PM
dlvalure's Avatar
Car: camaro rs (a tru sleeper)
Transmission: turbo 350
well my vortec heads are in the shop getting the works done to it like a 3 angle valve.....valve guides being cut down......and also bigger valves...i was wondering how big of a spring could i use can i use dual or tripple spring....and also what is a good lift?? i really dont wanna run anything over a .550 lift wit 1.6 roller rockers....just give me your input because this is really my first engine build and i want my motor to be strong and fast
Old 07-12-2007, 02:18 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I understand larger valves don't help Vortecs. Perhaps some of the 'sperts could verify that.
When the guides are cut, have the spring seats cut as well so something like Comp 981 springs will fit.
Old 07-12-2007, 02:40 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
Re: building vortec heads
I am no exspert but when I was getting info from different engine builders up here it was this. The vortec heads are a very good flowing head . The newer performance designs have the bigger valves. To take an older style of vortec heads with the smaller valves you do not have much work to flow as good as the newer style with the bigger valves.Mine now have 2.0/1.55 .You do not have alot of port work to do. Do a search on google and you will see some of the flow rates with a little port work and the bigger valves , you will be amazed. They are flowing alot better then alot of the aftermarket heads and can get them at a good price.
I ended up getting my motor built in the USA , I wanted to buy an aftermarket head, money was not the problem. I could not believe the builders saying why these vortecs are working real good with the right work done to them.
Old 07-12-2007, 03:39 PM
TGO - 10 Year Member
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Larger valves dramatically help the vortec heads, especially on the exhaust side at the lower lifts.
Old 07-12-2007, 04:54 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
True for the exhaust side. hard to go wrong with the bigger ex valve. The intake side is a little more involved.
If you won't be porting the intake ports don't go with 2.02" valves.
The head will flow less than stock with just the big valve installed.
If you'll be porting the intake port and need more than 240-245cfm then go with a larger valve than stock. The chamber needs a little work too when going to larger dia valves in the L-31 Vortecs.
With stock ports and valves .480" to .530" is plenty lift.
Full porting and larger valves helps the high lift flow. thats where .550" and higher lift can be of some benefit.
The cam manufacturer can recomend the right valve spring for your cam. Cylinder head machining will be required, reguardless.
Triple springs are for full race roller setups.
Old 07-18-2007, 10:58 PM
FreeLoader's Avatar
Car: 1997 Camaro z28
Engine: 350 LT1 built to LT4
Transmission: a
Axle/Gears: 3.23 posi
correct me if I'm wrong, but wouldn't too much exhaust flow create an issue if/when there's a valve overlap?
the stock 305 cam has no overlap if I remember correctly, but most aftermarket cams do, and if that's the case, wouldn't there be a point of no return on the exhuast flow?
this of course is assuming that you still want to pass emissions, or have a cat...or save the planet...
Old 07-18-2007, 11:23 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i guess theoretically there may be a point where exhaust flow could be detrimental but you wouldn't be anywhere near it with 1.6" valves...
http://www.nastyz28.com/forum/showthread.php?t=56505
a great thread about vortecs pretty much all you need to know
Last edited by SpitotRs305; 07-18-2007 at 11:27 PM. Reason: the new spelling...you know how it is
Old 07-20-2007, 04:31 PM
sstpres's Avatar
I've got a set of Topline Vortec replacements. These were pocket ported, an2/02/1.6" valves and a good valve job. All by Creative Flow Mgmnt. Here are the before and after flow #'s.
Intake Exhaust
.1 71/72 66/78
.2 127/128 119/135
.3 186/188 139/170
.4 226/231 143/183
.5 239/258 146/187
.6 236/260 146/191
The bigger valves didn't seem to hurt these heads. Really make a difference on the exhaust and at high lift.
84z96L31vortec
08-20-2017 12:16 AM
Tinbender59
03-17-2017 10:50 AM
bamaboy0323
09-03-2015 06:07 AM
L98GTA87
08-11-2015 06:55 PM
84z96L31vortec
08-10-2015 08:27 PM
Quick Reply: building vortec heads
