Vaccum leak?
Car: 89 Iroc
Engine: The 350
Vaccum leak?
I am having a problem wih my car. The engine knocks and it backfires. When i listen to the engine with the hood open it sounds like a loud winding noise. I was thinking there is a leak somewhere in my intake but im not sure. Maybe a bad gasget? any suggestions at where i should start would be great. Thanks
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: Vaccum leak?
put a mechanic vacuum guage on it
the carb makes a loud and constant sucking noise it is really hard to hear any vacuum leak over the noise
like already said check all hoses for cracks and such
make sure all vacuum sources in carb and manifold are plugged to a hoseor plugged off
try some starting fluid or something similar around the intake and carb gaskets while its running see if it speeds up
backfiring and such would not be a vacuum leak problem but rather an ignition timing or cam timing incorrect or valvetrain issue, messed up valve, a rocker nut tightened too much, a sloppy timing chain commonly causes backfiring also
how long has it been like this and if it didnt do it until something was worked on on the engine then what was it ?
what kind of knocking are we talking here ?
spark knock?
or top end knock or bottom end knock ?
low rpm or high rpm or ?
good luck
spark knock?
good luck
