convert 70 350 to roller cam?
Car: 1986 Z-28
I have a friend who's selling me his 350 rebuilt short block cheap. I would like to convert it over to a roller cam. I have a 91 305 roller cam motor that it is going to replace. Can I use the roller cam components for this? I realize that the spider that holds the lifters in place needs to be bolted down. So what are my options? Should I just put a hydraulic cam in and new lifters to save money?
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: convert 70 350 to roller cam?
every thing you need to know is here
https://www.thirdgen.org/forums/tech...+roller+lifter
but some quick answers
yes you can reuse the dogbones and spider yes it needs to be secured
No you cant reuse the lifters you need lifters from a V6 i got mine from a 94 s-10
and you need to run a thrust button
junkcltr
08-02-2019 11:12 PM
ambainb
04-25-2016 09:21 PM
MoJoe
09-24-2015 09:12 PM
