Can GM block #10134313 be use with wet sump oilling system?
Car: 88 IROCZ 350
Engine: 355 cu TPI
Transmission: 4L60 w/ 3200 stall
Axle/Gears: 9 bolt W/370 gear
I'm looking to buy a GM block for my Turbo project and block # 10134313 use a one piece seal crank, weight 214-pounds and has Slayed 20 deg main caps. The book also said that is intended to use with dry sump. Can this be change to a wet sump system?
Car: 88 IROCZ 350
Engine: 355 cu TPI
Re: Can GM block #10134313 be use with wet sump oilling system?
Here is what my engine bay looks for now.
Car: 88 IROCZ 350
Engine: 355 cu TPI
Received 1,839 Likes
Generally, yes.
All you really need is an oil filter adapter. Plug the comezoutta hole that normally takes oil to the filter, and hook your pressure pump stage to the gozinta hole.
Then all you have to worry about is your various scavenging locations. Which don't really have anything to do with the stock oiling system regardless.
{edit} OOOoooppppsss... I somehow thought that you wanted to do the logical thing, which would be to take a wet-sump block and convert it to dry sump; not the other way around. Especially since you're asking about a motor that will make considerably more power than a stock one would regardless. Downgrading a properly prepped racing block to wet-sump doesn't make a whole lot of sense.
If it doesn't have all of the provisions for a wet-sump oil pump, it'd be pretty tough to add one. Like, holes through the block, the pad on the rear main cap, passages here and there, etc.
Car: 88 IROCZ 350
Engine: 355 cu TPI
Generally, yes.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
nope aint gonna happen... the block isnt what makes power anyways...but thats not the point the 6cyl engine says it all they got extra room for thier stock items you have just enough room for them... most people have to move and remove most of their ACC. to run turbos and the other goodies
Car: 88 IROCZ 350
Engine: 355 cu TPI
1 Post
Car: 1987 Iroc-z Convertible
normally the reason a block description will say "DRY SUMP ONLY" is because the oil filter location is milled off the block. so there is no place for an oil filter. if you want a good block that is competion ready and still reliable look for a 184 block. these are the older nascar blocks before they went to SB2 stuff. the 1000 hp on pump gas can be done but it won't be cheap. and if it is going to be a street car you want torque anyway.
Car: 88 IROCZ 350
Engine: 355 cu TPI
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
