serpentine alternator on a v-belt
Old 05-19-2007 | 11:33 AM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
hey i was wondering if you could mix and match a serpentine alternator on a v-belt system, i have been looking for alternators for a v-belt, and the only ones they have for my car are like 70 amp ones, i need a high ampage like 140...
thanks
jim
Old 05-19-2007 | 11:42 AM
Re: serpentine alternator on a v-belt
i was thinking maybe if i ordered the serpetine alternator, and got a vbelt pulley, would that work?
Old 05-19-2007 | 12:05 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
what in the world do you need a 140amp alt for?
Old 05-19-2007 | 12:36 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Sure you can, i'm running the CS144 on my car with V-belts, that's the factory 140A one.
Lemme find you some info here;
Check my thread;
https://www.thirdgen.org/forums/elec...ght=alternator
this might help
http://oljeep.com/gw/alt/edge_Altern...html#Section_4
another
http://www.novaresource.org/alternator.htm
Most of those links are in my thread there. There's also one link (that I can't find) that came from a website that sells alternators, and it says what year vehicles have the CS144... '92-'95 Lumina and Pontiac Transport vans have them, it's an upgraded option. I got mine from a JY for $50, and a free resistor I stole from work. Thing seems to be working A-ok.
Old 05-19-2007 | 12:50 PM
i just finished putting my system in my car, and everytime i turn it on , e.g. my headlights blink, the sound fades in and out, this happened with my last car, i got a bigger battery for the car, that didnt help much, so im figuring a new alternator will keep the battery fully charged, in addition to my hyper voltage system thingy...
oh and thanks for the tips this is great
Old 05-19-2007 | 01:05 PM
ljnowell's Avatar
RUn a cap with your system, it can also help. Its no big deal really to switch the pulleys on the alternator.
Old 05-19-2007 | 01:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
ugh, i'd skip the cap completely. But check out the audio board, they've got more guru's there. Usually "the big 3" is all you need. But that depends on how huge the system really is.
RS Reaper
10-17-2018 08:52 PM
apie2546
10-16-2016 03:24 PM
jrdturbo
03-31-2016 03:58 PM
SRKLEGIN
10-03-2015 11:11 PM
raymondandretti
09-27-2015 07:43 PM
