Rear main seal
Car: 89 Camaro RS, 99 Sunfire GT
Engine: 2.8L, 2.4L
Rear main seal
ok. here's the problem. When I drive my car up to 1500rpm, I hear a rubbing sound coming from the back of the engine/front of the transmission. I also have a very slow oil leak between the engine and the transmission. I went on a road test with a mecanic I know that works for Chrysler (he does transmissions) and he says the rear main seal is leaking and is popping out causing the noise. And when I accelerate, the components pull apart just enough to stop the noise.
So do you guys think its the rear main seal, is it hard to do? Is it just removing the transmission and replacing the seal and putting everything back together?
I also have another problem. My oil pan gasket seems to be sweeting. Its full of crud. the crud starts half away on the oil pan and goes all the way to the crank pulley. Do you think it's just the oil pan gasket or more. And to replace it....is the exhaust going to be in my way???? since it bends under the pan.
and I think my shocks are blown in the front, it's starting to bounce a little...
oh and not to forget it's the 2.8 V6
thanks for any help.
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: Rear main seal
I've got the same problem. Rear main seal with a slow leak. It's fairly cheap to replace the part but you'll need a hoist.
Engine: 2.8L, 2.4L
Re: Rear main seal
the part is cheap, but ya I need a hoist. And if I pay someone to do it, then it will be very expensive.
LT1Formula
08-20-2015 09:36 PM
