Another "starting" plug suggestion
Old 05-16-2007, 02:42 PM
TGO - 10 Year Member
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
10.25:1 static cr
AFR heads
My AFR sheet says to use FR3LS which is now actually 41-629. Is this actually a heat range cooler than an R45TS?
Now if I find that I actually need a slightly cooler plug than the 41-629, what plug would that be?
Napa and the AC Delco dude he had on the phone weren't very helpful.
Found this at AC Delco:
Numbering
1st number denotes THREAD SIZE
2nd number denotes HEAT RANGE
In the early 1990s, an all-numeric, identification code was developed to ensure that the proper spark plug would be selected for replacement in specific engine applications. The numeric code does not in any way correspond to the heat range of the spark plug. Therefore, selection of a spark plug with a different code number is not recommended. The heat ranges may be drastically different between two different plugs, and engine damage or poor performance may result. See your local installer or retailer for details.
The prefix “41” stands for the manufacturer’s product line (e.g., 41 = spark plug)
Numbers after the prefix indicate the type of spark plug and also the specific application:
100 – 199 = Iridium
600 – 699 = Resistor
800 – 999 = Double Platinum
How are we supposed to change heat ranges now?
Old 06-24-2007, 09:53 PM
CamarosRUS's Avatar
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
Re: Another "starting" plug suggestion
TTT...I need a little help here too. But I need to find a compatible resistor plug to my Autolite 3923.
Old 06-24-2007, 10:48 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
check this out cross reference chart
Old 06-24-2007, 10:50 PM
Car: 91 RS
Engine: 350 vortec
even more useful still
evilstuie
02-28-2016 03:33 PM
86CamaroDan
09-29-2015 10:08 PM
Bryan F
08-27-2015 07:28 AM
transamgta1Khp
08-17-2015 12:18 PM
djmarch
08-09-2015 05:27 PM
Quick Reply: Another "starting" plug suggestion
