GM Goodwrench 305 heads
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
we have a junk 82 z28 crossfire we bought for parts a couple of years ago, it has a GM Goodwrench 305 with the rods through the block, but i was thinking about tearing the heads and the intake off, ill probably ebay or let the intake set in my closet for a later, less performance project, (i think they are neat) but i was wondering if the heads would be an improvement over the 187 L03 heads i have on my bird now. I would have around $100 in them going to a 1.94/1.6 valve combination I have no idea on the head on casting numbers, hopefully ill find out later, but i was looking for insights
Re: GM Goodwrench 305 heads
ok smart*ss if you really have no idea don't answer, you already got like 3000 posts, go spend some time doing something else, i just figured someone may be familar with these engines and know the casting numbers off the top of their head and if they were of any quality
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
The '82 Crossfire engines would have had 416 casting # heads, but if its a goodmark engine, i'm not sure what they would have used. I would guess it's the same, and therefore just slightly better than 187 TBI heads, IMHO. Barely worth the head gaskets to swap over, unless you fully port them up.
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
well i work about 70 hours a week, i don't get online too much, and yes the motor was swapped before i got it, and it is kinda a bear to yank the valve covers, it appears the manifold's upper blocks easy access to them, and its about 2 miles from my house, so i can't use any power tools, so it might take more than about 10 minutes
No diss to you Sonix by any means and this is not meant towards you, but if the motor was swapped, how is it relevant information when you know it is not the original motor?
they are 416's go figure, i also got a set of 14102191's from a 350 tbi are they any good?
Car: 1986 Camaro IROC-Z
Engine: 305 tpi
Transmission: BW t5 W/ short shifter
Axle/Gears: 9 Bolt 3.27 posi
im going to guess the casting numbers are probably 14044016? I have those heads and they came off a 80-85 305 HO, which is what the cross-fire should have had. BUT if the engine was changed then cant help.
-my two cents
-my two cents
Car: 96 isuzu trooper suv
Engine: 5.7 liter 4 bolt main
Transmission: 700r4 auto
Axle/Gears: Auto 4peed, 3:73
If you mind me saying I would save my pennies and order a pair of heads from eldlebrock, and an intake. This way if you decide to strip the intake and heads off you have a better chance of picking up a better set. The crossfire injection was a bad idea for the camaros back then. Thats way GM stop making production. At least Eldlebrock would give you better gas mileage, as well as performance. But that's my opinon.
Car: 1982 Trans-Am
haha, whaddya know, I was right. Even though it was a total shot in the dark.
There aren't many other choices that GM would have used on an aftermarket engine to replace a 305, there was a good chance it had the stock heads anyway.
haha, Jon, your 3 points in your sig? #3 kinda imposes on #2 eh?
Your 416 head right now are your best bet. Port them up and you're good to go. Use the 1.94/1.6" valves that you were thinking of putting into the 187 heads. You might be able to steal the 1.94" valves out of the 193 TBI 350 heads you've got. I stole the 1.94" valves out of some old 993 heads, saved me $60 or so.
powerhouse has a set of 1.94" for 24.95, im curious to see as how their quality is on cheap stuff, btw ill get my sig corrected
im a dumb*ss sometimes
ambainb
04-25-2016 09:21 PM
